hey I have 92 acura integra gs with 4 disc brakes. and also i have stock suspension. the problem im having is the camber is eating my front tires inside. What would be the problem, the lower ball joints? on the alignmkent machine both tires were minimum specs -1.3 degrees.
Also whenever i wash my wheels i notice that my front right wheel doesnt get as dirty as the left front wheel. would i need a new right caliper?
upper control arm ball joint and bushings are probably shot…change them…as for your brake dust thats normal butt…prob have different pads on each side …or one is defected…most likely your calipers are goood jus check the pistons and the rubber seal around it.
ok thanks but i dont think the pads are bad i just changed them for warranty because they were warped i think that side caliper is defective. the pads are the same.
On stock suspension the camber is not adjustable. What were the toe settings when you got your alignment checked? Incorrect toe eats tires way faster than excessive camber. Some would argue that camber doesn’t prematurely wear tires at all but I’ll leave the arguing to others.
