Please bump if you view the page. Thank you
I have a lot of parts for sale.
Pictures will be up as soon as possible
All Prices are best offer and Shipping and pay pal fees are on the buyer.
everything is in good working condition unless otherwise stated
all parts are best offer
I do have more parts for sale and they will be on this list shortly
please contact me about the parts listed only
text or email only
201 687 3396
99-09 Honda S2000
BNIB S2000 Ignition coils all in boxes. boxes were open to look at the coils but were not used I got them a few years ago to do a coil on plug conversion on my Integra but I decided I could spend my money on other things before I do that. I am asking $100 for all four because I just need to clean stuff out and to be quite honest I do not know what their current condition is because they did not come in plastic and they have been in my basement for a while. I did purchase them from Joyce Honda in Denville NJ brand new about 2 1/2 years ago again $100 obo plus shipping
JDM 97 Spec Type R and other B series
Type R oil pump good condition just needs new front main seal this is a jdm pump so no crank sensor location $50 for the pump only $80 with the oem jdm lower timing belt cover
Type R water pump good condition just needs new gasket $20
Cometic 84 mm B series Vtec head gasket bnib $80 shipped
Testing waters on my S4C B16 SIR Transmission
It is currently taken apart due to the OEM viscous LSD breaking. The cylindrical bearing landing that extends off of the differential broke off due to Kearny Engine Depot selling me the SIR swap with a bent half shaft and I did not realize until it was too late. I tried contacting a few transmission and drive shaft shops to see if anyone could repair it but I was un able to find anyone.
Other than the differential the transmission is in mint condition. I was able to drive the car with the full swap before the damage occurred and it shifted perfect and mad absolutely no noise. I am asking $350 + shipping in its current state. If I don’t get that no biggie I will just replace the differential and use it.
90-91 CRX SIR S1 Cable transmission. Internally in good condition no grinding or popping out of gear. No common cable bearing howl. It has a small hole in casing on one of the casing bolt locations on the bottom of the transmission. when it got the hole it was towed home and I replaced the it with my 91 ys1 transmission that same night. The case is very dirty. I am asking $200 + shipping
Ractive B16 2 piece 4-2-1 header $100
b16 sir wrinkle black valve cover $75
Correction of previous post. I haven’t seen the v/c for a while until today it has more chips than I thought.
Nology hot wires one needs a new end crimped on $40 in current condition will go up if and when i repair the issue
You can see cylinder 4 wire boot and crimp slipped off the wire
H Series
H23 vtec OEM header from the Blue Top with supper clean heat shield In excellent condition $50
02-05 EP3 Parts / K swap parts
EP3 ECU & ignition with key and all plugs to do the wiring Everything needed to run a k20a3 swap without Hondata Kpro comes with steering column because I don’t want to drill out the brake away bolts $200
EP3 Uncut engine harness and charge harness $250
SOLD
Type R Intake Cam
