Fuel Filter Fuse
Hey guys, which fuse do I pull to stop pressure to the fuel filter so that I can replace it?
Thx
If the key is off there is no need to pull any fuse. The pressure will bleed off when you open the line be careful.
What am I being careful of?
There is still some pressure in the lines when the car is off, but the fuel filter has a pressure relief screw on top of on of the banjo bolts, just loosen that before you remove the banjo bolts and you’ll be fine.
Is there a fuse for the fuel pump that I can pull?
thread closed
Why is the thread closed?
If you pull fuse# 24 There will be no power to the main fuel relay BUT IF THE KEY IS OFF THERE IS NO POWER or unhook the battery
if you want to relieve some pressure in the fuel system, remove your gas filler cap. whenever you get gas, you notice that when you open it, it sounds like its letting air out. IT IS. that will help a bit. hope this helps. BTW, glad to see you joined up over here darrell. this is a good place to look around for info, with some pretty good people willing to help out.
