just wondering if there is a way to fix my gauge cause everytime i fill my tank it never goes all the way to full, and my low gas light will turn on after it passes the E. any help to make it more accurate will help.
Probably something to do with the sender unit on the tank. My light hasn’t been working properly lately, and it could be a loose connection, but I’m betting on the sender.
I dunno. My light only comes on when the hand passes red. And I always put in more after it cuts off, and my hand only goes up to F, not past. Just takes a bit longer before it starts dropping.
Both my da and db1 start coming on at a little under an eight of a tank and then stay on as they got close to the light.
mine doesn’t even reach F, when full it only goes to an 1/8 right before the F
