Fuel Injector Help
Have B20b in a OBD1 90 DA Integra…problem is i have no injectors for that manifold (code:PR4-HF/2), but i have my injectors from my d15b OBD0.
  1. Will the injectors fit…fuel Rail and Manifold without mods ?
  2. Do i have to Use the injector pigtail from the OBD0 engine wireloom?
  3. Do i need a resister box ?
if yes to the question , can the resister box from a 90 DA Integra work
Thanks in advance
d series injectors do not flow the same as b. hit up ebay or your local junkyard, or wire the newer ones to work. don’t be :ghetto:
1: yes. both b and d injectors are 240cc. no issues
2:obd0 and obd1 inj. clips are different. you may be able to modify the connectors to fit. if not, i’d repin them. much more reliable, and clean
3: yes. and yes
d16y7 and a few other jdm oddballs are 190cc. type r are 270cc, standard d/b are 240cc.
Thanks
Injectors fit nice, just had to change the lil rubber things, got some from the shop…waiting on my electrician, have both looms in hand.
will let u knw how that turns out
