I have a 1991 Acura Integra with a b16a swap. Currently car wont stay running hooked up to scanner and telling me to replace the fuel injector resistor. Does a stock b18 one fit or do i need it to be for b16a?
all the resistor boxes are the same. since all low impedence are the same resistance
they are low impedence injectors though, right?
Hey thnx for the reply. But ended up bein a ecu problem.
you didn’t run low impedance injectors without a resistor box and fry the ecm, did you?
Nope see other post in other thread.
