i installed a aftermarket trick flow fuel system. In order to attach the the lines i had to use fittings (earl pluming). One of the lines is at a angle where i cant flare the the line with the fitting on so i bent it straight and made the fitting slide on.
My question is, is it safe to run with my fuel line like that? it had little dimples popping out in the line from where i bent it and dosent really sit flush around the fitting. Im worried about the fuel flow being disrupted or having a leak.
if not i would have to cut my firewall and cut the line further up and bend it there.
any help would be appreciated.
thanks x36242379423
