Hi I’m about to install a aftermarket fuel pressure regulator for by b20 swap.
I purchased this regulator… http://www.ebay.com/itm/370778902953?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
But I’m not sure if it’s a regulator or just a fp reader. I says it fits my vehicle.
Please help thanks
That’s just a pressure gauge that attaches to your fuel filter.
A pressure regulator sits on your fuel rail… search google for a picture of an aftermarket regulator and youll see the difference.
yea, the ad even says its just the gauge. dont blame ebay for your mistake. you should of asked before you bought it. either way, you would need it to adjust your fuel pressure anyway…
buy the aem fpr and rail and be good to go…
Or leave it OEM. No need for adjusted fuel pressure for a B20 swap.
If this is the same guy as before then he was already advised to leave it stock and an aftermarket fpr would do him no good.
If this is the same guy then he did not listen.
So if this is the same guy, he will continue to not listen. So i am just advising on what he WANTS to do as apposed to what he SHOULD do.
Its one of those, ‘‘i ask for the opinion of others but never had any intention of taking it’’ cases.
Wow…
if u don’t know the difference between a fuel pressure regulator and a gauge you probably shouldn’t be installing one on your car…
+1
