I need to raplace my fuel pump, can anyone give or show me the instruction on how to raplace it… its my first time doing it so i need some info… i been doing research but havent found anything that will help me… do i really have to talke the whole fuel tank out??
please help me…
thanks…
Yes you drop the fuel tank.
Jack the car up.
There are two big ‘bands’ or strips of metal that are bolted to the car, that you have to remove.
After that, there are a few fuel lines and wires you need to disconnect. Make sure to label them if you wont remember how they go back together.
Drop the tank.
Replace the fuel pump
Repeat the process in reverse.
[QUOTE=unified112;2173715]Yes you drop the fuel tank.
Jack the car up.
Drop the tank.
Repeat the process in reverse.[/QUOTE]
Thanks man… thanks a lot
take a wire brush or wire wheel to that long bolt the holds the straps to the chasis. before you loosen it. it will make you life a little easier.
be very carefull of disconnecting the hoses. IIRC some of them are a discontinued part
