So its my 92 integra turbo.
So as for fuel stuff it had just DSM 450 injectors. Well tonight i installed a walbro 255 now when i come to stops it idles down then dies.
Has anyone had this problem or any ideas abt whats going on?
Thanks James
Thanks James
Make a thread in the proper assistance forum. General Discussion is not the place for help threads.
http://forums.g2ic.com/announcement.php?f=29
POSTING IN THE CORRECT FORUMS
So you’ve run a search and didn’t find anything, so you need to post a new thread. G2IC forums contains A LOT of different boards. Each one has a description. If you need HELP with something, chances are you need to post in the ASSISTANCE section. ASKING IF A PARTICULAR PRODUCT IS GOOD SHOULD NOT BE POSTED IN ASSISTANCE, BUT RATHER IN THE PRODUCT REVIEWS FORUM. You may NOT post in the General Discussion forum (or any other wrong forum, depending on your subject) just because you think it will get more attention and you’ll get your answer sooner! Read each forum’s or category’s description to help you decide which forum you should post in. It’s a no brainer. If you post in the wrong forum, the thread WILL get (re)moved and you may lose track of it.
