ok ive been have problems with my fuel pump not priming id let it sit for a few minutes come and it would prime and start
i went thru and check the mfr and it checks out good
so im at a loss here could my problem lye in the fact that im running a jumped ecu and distributor??(obd0 to obd1)
If the PGM-FI Main Relay checksout fine then the problem is the fuel pump or wiring going to it.
Next time pump does not prime, tap the PGM-FI Main Relay afew times to see if that will make the pump prime,if it does repair or replace the relay.
You can do the same with the fuel pump, next timeit does not prime, smack the gas tank hard a few times, if pump primes, replace the pump. 94
ok if it does it ill give it a shot but i went back in and change the disitributor and ecu back to my obd0 and it starts like a champ is it possible that there is something wrong with the other ecu??
[QUOTE=91b20teg;2156716]ok if it does it ill give it a shot but i went back in and change the disitributor and ecu back to my obd0 and it starts like a champ is it possible that there is something wrong with the other ecu??[/QUOTE]Definatly, the ECU/ECM is what controls the fuel pump relay. 94
