As i was replacing the carpet in my DB this past weekend, i saw, what seemed to be, the fuel pump being accessible from the top, without having to remove the fuel tank from the bottom. I dont have to replace mine as of yet, but i made mention, from my assumption, quick view, that the fuel pump can be replaced w/o dropping the tank. Is my assumption false?
Your right, three little screws and access to the fuel pump is possible. Subies are like that as well.
ok, i’ve been told twice since i did my carpet and made mention that it could be accessed from up top that it wasnt so i was double checking and my search on here brought up nothing
Gas tank needs to be dropped to replace fuel pump.
What you are accessing above the rear seat is the fuel sending unit.
http://forums.g2ic.com/showthread.php?204378-fuel-pump-location&highlight=fuel+pump+location
ok thanks mike
