Fuel Pump
Will I be able to replace my fuel pump all from the inside of the car (under the back seat)? and Im having trouble locating the main relay for the fuel pump I searched the Haynes Manual but that only shows me but so much unless I missed something any info will be apresiated. And she is still down I have an ECU on the way my reason for replacing the fuel pump is because I folowed a scramatic and from the batt it went to the fuel pump. Check my last post and let me know if theres anything else you can help me out with I need my baby back on the road.
Main relay is a semi big square under the driver side kick panel, under the steering
I found it man thanks it seemed fine but I might mess with it and open it up just to check it out…
If you can fix it then good, other wise it’s best to buy a new one for $60. Trust me that relay makes you’re car idle and run like crap if faulty.
