Fuel Relay
Hi,
I recently purchased an 1990 integra. When I first bought it, the guy coudln’t get it to start.
Not carrying, I still purchased it.
Parked it in my garage and started to check it out.
When I’d turn the key, the engine would turn but nothing would happen.
So I got a buddy to turn the key while I would listen for the fuel pump kicking in. Nothing.
Drop the tank and connected a jumper wire to the bat direct.
Pump kicked in and started to pump gas.
Turn the key and BOOM car started.
Ran a wire to another wire that was hot only when key was at the “Start” position. (Temp fix… Winter was coming and I couldn’t leave it in the garage.)
So, thereore, Pump works, ground is good. Something to do with the relay right?
Should be just a matter of getting a new relay and reconnecting the wire to the relay right?
http://www.g2ic.com/forums/showthread.php?s=&threadid=55129&highlight=main+fuel+relay
:smiley:
Hit me up on MSN next time you’re on… :slight_smile:
~Eric
