Im thinking of getting the traction bar. knowing that it eliminates the center beam… would it affect the rigidity of the car esp that part??
The front crossmember is the same on both the ls and gsr models. The trackion bar dosnt stiffen up the front chassis. It takes away all the the slop in the rubber bushings which helps you to gain traction, hence the name traction bar
Imho this is one of your best uprades, especialy if your serius about drag racing
OK. I just thought that only GSR’s didnt have the center beam since the chassis is thicker compared to da6/db1’s… but thanks for the info…
the chassis are not thicker from what i know.
