Hey all, ANY of you have any wierd creaks after putting in the FUll Race Bar?
yes,
Im not 100% sure if this is correct but I think I remember tightening down the two long bolts that hold up the traction bar to the bottom of the frame rails. Once those were nice and tight the creeking and cracking sounds stopped.
Either that or they just go away after a while. I haven’t heard them in a long time.
I get some noise from the heim joints rotating sometimes - more of a popping noise than a creaking one. Make sure the heim joints are greased good.
yea i get more of a popping noise from the joints on hard stops, turns, and sometimes hard luanches, but its normal. everyone that i know that has the bar, or any bar for that matter, will have these noises
Hows the traction increase on these? Thinking about picking one up for my boosted tractionless integra.
MantisX
:whew: ive been searching high and low for that noise and even though I knew it was comming from the traction bar, I couldnt figgure it out
I get creaks when going over bumps…
that might be the springs:shrug:
Has anyone ever determined, what exact part on the T/B is making the clunking sound during hard braking?
I’m with MantisX
How is the Traction increase. Is this bar noticeable when driving. Even everyday driving conditions? (spirited cornering) Does the bar make a big difference. I’ve been on the fence about it.
Thanks
With fairly low tread on my tires, axles shaking under acceleration, and an open diff, I still noticed some difference with the traction bar. Definitely stiffened the front suspension and helped out some with wheel hop and traction (like I would still spin the tires, but not as bad and would be moving forward decently despite the traction loss). Since then I installed a Quaife LSD, got a new set of Dunlop Sport Maxx tires, and installed a set of Raxles. Now my car sticks like glue - might get a little chirp when starting if I’m heavy on the throttle or a little slippage going into second, but no wheel hop or major traction issues (even if I do lose some traction, I’m still moving instead of sitting and spinning the tires). I’d say it’s working pretty good now, but you definitely need good axles, tires, and LSD as well.
[QUOTE=BLKACK1;2095668]
Has anyone ever determined, what exact part on the T/B is making the clunking sound during hard braking?[/QUOTE]
If you have the traction bar torqued down properly, the only part that can move is the radius rod (or a bad engine mount). I have heard mine make a popping noise rotating one way when starting off and then rotating back the other way when braking. I have taken my hand and turned the radius rod back and forth really quick and it definitely was what I was hearing and feeling.
BTW, the big bolt and nut on the end of the rod that goes through the heim joint and attaches the rod to the bar is supposed to be torqued to 80 ft lbs (there isn’t a factory spec that can be applied so I had to get that spec from Full-Race).
phatcar
thats kind of what I figgured it was and good looking on that tourqe spec. I was wonder what that was. I just did hand tight, but know I can go back and actually tourqe it down.
I wanted to bump this up, I found what was making the clunking sound on mine. the three tow hook bolts managed to loosen up and was alowing the bar to shift around. went back and retightened them and havent heard it since:up:
Got my Full Race installed last week when my turbo got dropped in, and the tuner said I need to get an alignment because of the traction bars for DAs doesn’t let you line up the caster or something and they had to eye ball it? I dunno but it makes those same creaks and if anything rides like shit when going over bumps, so is he right that I need it aligned or did he screw up the install cause I never heard of needing an alignment after a traction bar install.
Thanks.
Coz
You need an alignment when installing any new suspension component. Unless he measured the stock radius arms before removing them and set everything exactly as it was (which is almost impossible), your alignment is going to be off. Oh, and I personally set my caster to about 1.1 for a neutral stock feeling.
Alright cool. Gonna probably take it for one this weekend when the damn rain stops.
Coz
How close to the front forks are your radius rods? Mine look a little close right now, just wondering if that is normal.
I do remember mine looking close, but they have never touched.
Are you boosted guys running the front mount? I was about to order the full race bar until I saw that mount. Any clearance issues on a turbo car?
I was also looking at the esp set up but I HATE how the square tubing looks.
Shouldn’t affect your FMIC at all.
I’m assuming you are talking about the motor mount?
