is anyone running thease function forms on their da? just curious as to how low you can go on thease. thanks
im subscribing to see if these go lower than ksport or if they are the same.
///Nick - Didn’t you reply to a certain thread that had a pic of what the drop looked like on a teg?
I was searching for this last night and found:
http://forums.g2ic.com/showthread.php?205012-Best-setup-for-700
HTH
heres a current pic of mine with type 1 coilovers. to get the front any lower FF said to order eg/ek lowers and forks.
[QUOTE=SloDezl;2175582]heres a current pic of mine with type 1 coilovers. to get the front any lower FF said to order eg/ek lowers and forks.
What’s the ride like? What springs are you using also? By what springs I mean ratings?
[QUOTE=MoRBiDThOuGhTs;2175267]///Nick - Didn’t you reply to a certain thread that had a pic of what the drop looked like on a teg?
HTH[/QUOTE]
haha you found it, i tired looking for that but i had no luck. so what other front forks can you run to make the car lower?
im jawlzin at youre driveway, do you scrape much?
it dont scrape much just about 8 bags of the asphalt filler you can by from homedepot to lessen the shitty angle of the driveway . it rides good for the height and the spring rate is 10k fronts and 6k rears.
Thanks for that info. I’m planning everything out and don’t want a harsh ride. This is my daily so I have to live with it for long rides around the pristine smooth roads of San Diego.
the best thing to do is order the front struts with the eg/ek lower mounts and go to the junk yards and pick up eg/ek lower wishbone and the ride will be good and it will allow the car to sit lower than using the da front wishbones.
what kind of camber kit r u using
EG Function N Form Type 1’s, tucking 165/45/15 tires. ![]()
People must love buying CV axles every 3 months
for the love of kragen lifetime warranty axles :DD
How many inches are you lowered front and back?
