function form rear LCA won't line up with stock sway bar
The sway bar hole on my function form rear LCA’s sits a lot lower than the stock location. It’s kinda off to the side as well, making the bolt hard to push through. The sway bar bushing doesn’t really seat in the hole either.
When I do get the sway bar bolt through the hole, the arm sits way too high.
Is this a bad design or what? What rear LCA’s are others running? I looked for function 7 but I don’t see DA applications. grrr.
I got the skunk2 version with the three holes and adjustable endlinks. Everything lined up perfect and if it didnt i am able to adjust my endlinks to proper height so maybe you should get some adjustable endlinks to solve that problem if nothing else works.
you need different end links. im sure if you searched you would have found that out.
X2. Search and you would have saved some time waiting for replies, but you need adjustable endlinks…
