I’ve been searching came up with a lot of info on reloacating, but I am curious what the wire coming from the 10A fuse on the positive battery terminal goes to.
A fuse on a lead from the batt. terminal is not stock, none of my wiring diagrams show a fuse of any kind until you get to the engine bay fuse/relay box, or the ABS, [if you have it] fuse box, [also called the auxiliary fuse box.
Questions…
What year is your G2?
What is the trim level/model of your G2?
What color is the wire that the fuse is on?
What type of fuse and fuse holder is it?
Can you post a pix of the fuse and fuse holder? 94
help help whats wire is this
sorry to bring a thread back to life…after i did so i said to hell with it and pulled the wire out and checked over things… it was the hazard wire
