G2 Teg Beaks Lower Tie Bar
… Help me out g2ic anybody installed the beaks lower tie arm bar on a DA … Can u post some pics… Is it barely visible under the chassis
http://forums.g2ic.com/showthread.php?201659-StreetKnight408-s-1990-Integra-RS-Build-Thread&highlight=
Pics are in the middle of my build thread. Had to drill the holes to the LCA bolt portion a slightly bigger diameter. Simple wood drill bit should suffice. Holds up good; had it for 8 months approx. It will scrape if you go over speed bumps a little too fast. I haven’t dented it yet.
To be precise on appropiate pics, refer to posts #13 for close ups and #19 for a pic of how it looks with wheels on the ground.
