I recently bought a 91 Teggy with a B18a1 engine, with a GSR tranny. When I’m in 5th gear around 70, the gear “spits” as if it’s misfiring. The previous owner said that it’s not a problem, that the spark plugs need to be gapped. Again, it only happens when I’m in the higher speeds. How do I gap the spark plugs? Thank you.
Doubtful that the gap is your problem. Obviously you should check, but I wouldn’t get my hopes up. Every time I’ve ever bought spark plugs for a B series engine they have been in spec or close enough right out of the box.
I replaced the spark plugs and I still get a random misfire while driving. Could it be the O2 sensor going? I’m going to change the rotor and cap soon.
