gas gauge off?
my gf just got a da and the fuel pump was just replaced but the gas gauge is off. at like 1/4 tank it bogs out and shuts off. what could be the problem? thanx
there’s a float on the sending unit which registers the fuel level through a variable resistor. it’s basically a wire with a little buoy at the end of it. if that wire gets bent, it will read incorrectly. or if the resistor pack is damaged. that’s how a typical sending unit works. pretty sure da’s use the same mechanism
was this problem occurring before the pump replacement?
