how do you fix or adjust the gas tank cover. it doesn’t go in straight it stick out a little.
I had the same problem all you can do for that is too just bend it a little at a time,and see if it works …good luck
2 10 or 12mm bolts that hold it, can also adjust it. Otherwise adjust the tab that holds it in.
