so i just got another da and found out the tank has a leak… first i repaired it with jb weld and found out there is another hole higher up or on the return line… well my question is is there any other gas tank like an ef crx ect that will fit a da and or how hard is it to drop a tank on a da droped a eg, and fox body mustang but never a da??
two 14mm bolt an disconnect the lines it eazy oh an unhook the wires under the back seat
too bad my car seems to think easy is over rated…
It’s not quite as easy as he makes it seem if you have gas in it. I just replaced two fuel pumps in the same day recently. There’s a little skid plate on the driver side of the tank, unbolt it from the frame.
Unbolt the breather line and the fill hose.
Place a jack under the tank, unbolt the straps. Bring the tank down, remove fuel lines from top of tank and unplug fuel sending unit/fuel pump harness up top.
Remove tank, install is reverse of removal. Find another DA tank, I don’t believe any others will work. When you re-install the tank, try to replace the fuel lines while you’re under there. 5 bucks worth of hosing to prevent you from doing the pull again.
that about sums it up, droping the fuel tank is not difficult but it helps to have an extra pair of hand, maybe even 2 pairs to make the job go smothly
Im also going to add, having air tools for the strap bolts helps imensly. I also take a drill with a wire wheel to them prior to lossening them up to get all the bult up crap and rust off of the threads:up:
