gasket maker for the passenger side leak?
so i got this gasket maker stuff just like silicone. can i use it to seal my leak?
well you could only if you removed the wipers and air vent cowel to access the torn rubber gromets that water is leaking threw, after all that work you can pop em out or just fillem with silicone then reassemble evertyhing and they should hold water back once they dry. But i mean just buy all 8 gromets and replace them, its the least you can do after all the work it takes to even reach them.
keep looking around I think someone took pics of this process.
just replace them with the proper part. there about as expensive a tube of silicone so why not do it right in the first place.
I agree^^ I to tried to use silicone to fix my leak and it still leaks.I even got a can of clear silicone and sprayed in every spot i thought was leaking and that didn’t even work. Just fix it the right way.
my car does the same thing does anyone know the part number?
