Hey guys.
So whenever I shift up into 3rd gear, it grinds so nasty. Only when shifting into 3rd gear and never when downshifting. Originally, I thought it was the shifter bushings because they were torn to hell. Today I replaced them but I'm still getting the 3rd gear grind.
Any ideas of what it could be?
Sorry if repost. I’m on my phone and in a rushed time frame.
Thanks! :burnout:
Let me add that I just replaced the clutch not even a month ago.
Sounds like old synchros. Very common. Check out a company called synchrotech. They make carbon replacements that are better than stock, and cheaper I believe. I had the same problem put em in and it’s all better.
I’ll check that out. Thanks!
That will require complete teardown of the transmission… have you checked you fluid level?? if its full, I would recommend try running syncro mesh 2 in the tranny. this wont get rid of the grind but should help quite a bit and make it a little less noticable. if you want it to go away outright, that 3 gear syncro is gonna need to be replaced and if you in that deep, theres no point in just replacing 1 syncro… might as well replace #1 & #2 syncros as well as the old bearing while your in there($$$$$$$$)
Yeah, Ive gathered that by now. Im considering checking pull a part for another tranny with lower mileage. That or drop $1000 on a rebuilt one.
It would be cheaper to buy the synchros and have them installed. They come in kits 1-5 or 3-5 gear. Mine cost maybe 300 bucks to get done. That is synchros and install.
Ah sweet. Ill check around for pricing and see what the best option is. Thanks!
