How the hell can I get my fog lights out? I have the little clips off and I loosened the side bolt but its stuck from the side right next to the headlight. What do I need to do to get this out! ![]()
Thanks!
(92 GS-R)
Thanks!
(92 GS-R)
no help eh? I cant believe this is that hard…
Dude, chill… you gave us a WHOPPING 28 minutes to answer. LOL…
Have you tried wiggling it? shoot some liquid wrench or WD-40 in there to loosed the rusted metal where the bolt was (that you took out). If that doesn’t help, blame it on leprachauns. ![]()
~Eric
lol, I was just playing around heh. The bolt on the side wasnt the problem, I got that off, but between the foglight and headlight there was something holding it in place. I couldnt see what it was because the lights are so close together. Not quite sure if it was a bolt because I could swivel the light around, but it just wouldnt come loose. I hope that made some sense…
Don’t think there’s another bolt, but there is a little plastic nipple that sticks out from the foglight, into a hole in the headlight assembly. Try pulling the foglight towards the hood latch (towards the opposite headlights), and then see if it comes out. Also, maybe pull the inside edge (edge nearest the hood latch) towards you, and then once it’s out a bit, pull the other half.
Shouldn’t be hard… I remember getting mine out in under 2 minutes. ![]()
~Eric
Lol, you must be crazy good at getting lights out ![]()
I had everything but the ‘plastic nipple’ part out, but I didnt want to just force it because I wasnt sure what was holding it in place - thought I better ask before taking the risk of breaking it. Thanks again man!
