After getting my 93 teg out of the shop yesterday i was driving around int the yard and down the street everything seemed to be fine with the car but a small coolant leak. so i fix the kleak and when i went to start the car back up it wouldnt start up. so i checked over everything and notice that the guy who worked on my car didnt put the circle gaskets on the valve cover, so now my spark plugs were filled up all the way with oil. today i cleaned up everything and put the gaskets were they were supposed to be. now when i turn the key in the ignition 3 clicks, its getting feul. but the problem is the battery, check engine, and oil pressure lights dont come on. but the lights on the riht side of the cluster lights up and the car chimes when the door is open. any body knows what it is or had this happened to them? im thinking its the spark plug wires.:argh:
http://forums.g2ic.com/announcement.php?f=29
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
