The screws on the top are so tight. i sprayed wd-40 but they dont move. i got 2 off and the otheres either dont move or strip. anyone gota tip how to get it off. im trying to switch bumpers
Vice-Grip.
x2
These are your friend.
where do i grip the vice grips to? the bottom were the bolt comes out of the nut? those screws would b helpful if it wasnt so tight
yeah i hate it when i just hit it with a screw driver and endup stripping the nuts.hope the vice grip works.
the one in the middle works.
carefully heat up the screw you’re taking out from underneath. dont heat it too much though or you’ll start melting the bumper cover…
those 2 things i showed you work awsome for me. especially with rear bumper supports (always rotten and siezed up)
also make sure you use a good phillips screwdriver that fits very well. :read:
