Glove box light
Did the glove box light only come on some models?
yea i would like to know that toooo… help?
Well I have a 91 LS and mine has it… that’s something for you to cross reference with…
mine is a 92 rs and i dont seem to have it. or i just can see where it would connected too?
If I remembered correctly, the light is located on the outside upper left of the glovebox. Maybe you have one but the bulb or connection is broken? Just check along the outside of the glovebox and maybe you’ll see it.
Half way inside the glove box on the left side there should be 3 strips of openings i think that mite be it but mine is also out to. Thats my best guess.
that what i thought as that the bulb was out so i pulled out the box. and there is a spot there for it but no light housing and no connector. maybe the glove box light was too luxury for my 92 RS
same here i just pulled it out when i read the post and nothing. damn acura
Oh… then maybe you guys with the RS don’t have a glovebox light… I’ve owned two LS’s and they both have it soooo…
haha DAMN RS lol now i can see my condoms in the light.
thats pretty ghey. oh well i guess ill have to go poke around the pick n pull and see if i can find anything.
Exactly… you get one from an LS and swap it in there… it should be just a straight swap. Then just hook up the wires for the light… good luck!
i didn’t see a 2 pin connector in the hole. are the wiring harnesses different too?
Yes. In many ways.
I got a gs i think mine is out then…any tips on takin the glove box out?
It’s simple there is two screw on the outer edges of the glove box. you can see take those out. On the inside of the bottom are two caps hiding two crews take those out. and finally the two screws holding the metal latch and remove it. Then just pull it out
