goodridge brake lines come with banjo bolts?
did it come with seperate banjo bolts and copper washers (that connect to caliper)? or am I suppose to use the stock one? i got these lines used from a friend along with cross-drilled rotors and forgot to put the stupid bolts in the bag…
u can use the stock one, and don’t forgot the thin little washers
A new set will come with bolts and washers. Looking at mine right now. The hardware bag also has 4 square ‘U’ shaped brackets in it.
okay thanks!
this will be a mess trying to get it on…caliper bolt and hardline nut dripping fluid all over the place.
