Got two interior issues, so I figured I’d try to cover both in one thread.
The steering wheel problem - Bought a grant challenger plus the appropriate grant kit for my '91 DB1 today from autozone, had $20 on my rewards card and end up only spending $20-25 so I figured why not. I knew when I bought it that I would no longer be able to use cruise control unless I ran new wires to new switches somewhere else on the dash or something, which was fine considering my cruise control box is faulty anyways. The problem I’m having is with making the horn work, by default the grant wheel and kit combos will NOT let you use your own if you have cruise control from what I’ve gathered so far with my car. I’ve been following this teg tip for a fix…
http://g2ic.com/forums/showthread.php?t=151623
I just can’t seem to find a good sturdy strip of conductive metal to use. Anyone know of a particular item from a particular store like Radio Shack or Wal-Mart that I could buy for cheap that would have the type of metal strip I need to do this horn fix? Some guy in that thread mentioned a flash-light from radio shack, but I don’t want to buy every flash-light they have in order to find the one he was talking about. Some flash-lights have a 1/4" wide strip of metal from the tail-cap to the switch or bulb assembly, on the inside of the light’s body…something like that would work great but I’m not sure what lights have it.
The fan speed problem - My fan speed control does not work on setting 1 and 2, but works on 3 and 4. If the a/c button is clicked, the light turns blue and I can feel the compressor kick on when the fan speed is at 1 or 2 meaning the rest of the system acknowledges what speed it’s on, but the blower motor doesn’t. I think this happened after I pulled my blower motor a year ago to remove a blockage in the turbine.
What would cause it to not work on 1 and 2, but work fine on 3 and 4? Bad resistor on the blower motor? Bad connection at the blower motor? If this has happened before to others, what was a common fix that seemed to work?
EDIT: Searched again using different terms for the fan speed issue, turns out that it is most likely the resistor. Will get a new one ordered.
