grinding noise in wheel
Every now and then I would hear a grinding noise near the right wheel when I brake. I just got my car tow and now I hear a clicking noise near the right wheel when I reverse. The grinding noise is still there when I brake. Do anybody know what could be causing this?
Does any body have an idea what is wrong?
Thanks
Check your brake fluid and top it off. See if your brake pads are worn also. I had the same problem
What you can try is jack up the car and rotate the wheel by hand and listen to pinpoint where the problem is.
