Groggy Start up
Hey guys I have 92 teg,
first of all the starter is going out, sometimes it starts up on the first click, other times I have to click it over and over and over before it turns over, that problem should be the starter right? hah,
then after running it for a little while, (about 15 minutes at most) if I turn it off and try to turn it back on it starts up really groggy but then evens out and idles where it needs too, any ideas of what this might be?
o2 sensor…
mine was doing that after it was warmed up… mis fires, groggy. than would idle & drive fine after I got it to run… my issue was only on warm starts. ( I.E car had been running 15 or more minutes and was at operating temps)
get a denso sensor on ebay for 20-25 bucks
As far as the starter, pull it out and take it to an oreilly’s auto, or parts store. most can bench test it to verify if it is good or bad
