Alright just picked up a set of these and decided to install them today.
Ran into one problem the supplied slip sleeve that slides between the shock and the coilover does not fit.
I checked the box to notice that it says 90-93 integra w/stock I then found my old stock shocks and slip sleeve fits right leaving no movement.
Does any one know if these spring numbers are for the stock shocks?
Front 200.64.58
Rear 200.64.44
What kind of shocks are you putting the ground controls on? If it’s koni yellows you have to buy the set of ground controls that fit them.
According to a couple places the gound controls that fit the stock shocks also fit all tokico’s as well but doesn’t say anything about fitting the KYB AGX’s. Maybe give GC a call tom. or wait for a response from someone else. I just know that yellows require a different set of GC’s. Sorry I couldn’t be more help.
All good thanks for looking
