Ground Control Top Mounts & D2 Coilover
Hi!
If somebody know if this Ground Control Honda Top Mounts will be working with D2 Coilover ??
http://www.weaksauceparts.com/store/product.php?productid=19626&cat=2361&page=1
Thanks for answer !!
do you know what purpose the ground control tophats serve?
it is to extend shock travel, the D2’s adjust from the bottom mount
so these will be pointless
edit: i would use the tophats on these pro S, but not on the pro C
watch the video you’ll understand what im trying to explain
PRO S
http://www.youtube.com/watch?v=ytG4LlWvEkI
http://www.youtube.com/watch?v=sqn2hmwAUtU&feature=related
http://www.youtube.com/watch?v=eL3VxYc87VE&feature=related
I lowering car in front on maximum and my shocks not working proper. So that top mounts relocates shock upward 24mm to allow extra suspension travel. But I`m not sure if its working well with my D2.
measure the shaft on the D2, the koni comes in 10mm and 12mm IIRC
i have 12mm. So i`ll fit this top mount ??
yeah it should fit, just buy the ones meant for koni shocks
