Ground Control Vs. Skunk2
Ground Control or Skunk2? I have a 93 Integra, and Tokiko Illumna Struts, I want a smoot but firm ride, I don’t want my car to bounce when I go around corners, and I don’t mind a mildly stiff ride.
The springs that I bought my car with are wayyyyy to stiff, plus the struts are going out. So when I go around a corner my car will bounce, which is bad.
If you get skunk2’s maybe you should look at the ones made for civic’s since they have a softer spring rate.
also Groundcontrols have the best ride.
i’ve got the skunk2’s on illuminas. and yeah, they are pretty stiff. The main reason your suspension is going to be sto stiff is the shocks. From what i hear you can run koni yellows with the skunks and the ride is much more comfortable.
if you’re worried about the ride being too stiff, i would either get the GC’s or like sir rev alot said get some civic skunk2’s. they fit exactly the same but are a little softer than the teg skunk2’s (but still stiffer than the gc’s.
Well, I am not really worried about a stiff ride, I am worried about my car bouncing over bumps during turns and stuff.
hey ocbeta, what kind of springs do you have on there now and how much of a drop are they? i’ll buy them from you if they drop enough and are in good condition
The springs are in good condition, I am not sure how much of a drop they are, they are pretty dang stiff, :smiley:
With 195/50/15’s They are almost flush with the wheel well, not too crazy of a slam, but low enough to look good. I believe it is a 2" drop in the front, and a 1.5 in the rear. I am not sure what kinda springs they are, but they are not cut or heated.
MAKE OFFER :smiley:
hmmmmm… do you know what brand they are? how about $75? i don’t care how stiff they are, i just need some inexpensive springs to set my teg down on top of my 235/40/17’s!
I am not sure what brand they are, I bought the car lowered. They seem to be pretty good springs considering they don’t bounce a lot. I am probably going to get a set of GC now, I canceled my order for the skunk2’s, I will let you know when I get the GC’s, it should be in 2-3 wks. I will give them to you for $75 shipped, how does that sound?
hey, works for me. 2-3 weeks? right on, heh i’ll need that time to find the money. just let me know when you’re ready to sell em
