ground wires
im planning on redoing the ground wires in my engine bay but the only issue i have is not knowing where they are. does anyone know of any chart or something that shows where all of them are?
the only 2 i know of are the ones on the valve cover to chassis and the one under the battery…
valve cover to the rad support, from the neg post on the battery runs under the battery tray to the engine bay, and there is one by the starter just look you will see them :search:
these are 1 ground, it goes from the negative terminal to the transmission, the middle of it also bolts to the chassis under the batery
thank you. i was curious if there were more than just 3 ground connections somewhere in the engine bay.
