I installed an S2000 antenna and I get static (like a whine) on AM when the car is running. But when it’s turned off it’s fine. Is this a grounding issue? If so I think I might know where the fault is. If not, what could it be?
TIA
likely a loose or corroded ground.
But who listens to AM anyways?
:uhoh:
~Eric
bingo. also realize the s2k mod doesnt yield as good reception as stock in the first place… but it does look good tho! =P
Re: Grounding Problem?
TIA
Where did u get your S2000 antenna? and for how much?
