gs head question
someone on the board is sellin a Complete just rebuilt GS head w/ cams
i got a b18a1 with an auto tranny
“a 3 angle valve job was just done along w/ new valve guides and valve seals, also milled head not much but should raise comp. ratio .2”
what should i expect from this change
is it a step up in hp or performance or both
and do i have to do any thing xtra on my end when installing
do i use the same distributer
any other mods
thanks
jr
Re: gs head question
Originally posted by cdremixes
also milled head not much but should raise comp. ratio .2"
how much was it milled?
there is such a thing as too much milling esp depending on what octane gas u have where u live
only real way to tell would be on a Dyno before and after. anyone telling you otherwise is wrong or just plain guessing, but with headwork u “should” see a an increase on both levels
any other mods
thanks
jr
just swap over everything from your old head to the new one, but might as weall get new gaskets rather than reusing the old ones, and yes your distributor will work HTH
thanks bro :smiley:
