gsr feels weak
i have a 92 integra gsr
sometime it stumbles upon acceleration or feels slow
but other times it runs great and is fast as ****
whats up with this bad running?
by the way all i have on it is intake
it got a big tune up like 8k miles ago
fuel filter, cap, distributor, everything bascially
whats wrong with it?
maybe you just need an oil change?
probably plugs and wires though.
check your main fuel relay, fuel pump and try an injector cleaner.
how do u check the main fuel relay? and fuel pump?
i jus put in injector cleaner so thats not it.
serious i prolly jus need an oil change?
how often do u have to replace plugs and wires?>
what exactly was done during your tune up?
distributor cap
rotor
distributor housing
timing belt tensioner
fuel filter
spark plug seals
spark plugs
fuel injector cleaner
timing belt
oil seal
cam seal
thats all that was replaced
try changing the O2 sensor.
how come they didn’t change the spark plug wires? seems like they changed everything else except for that. also as recommended previously, an oil change wouldn’t hurt.
when it runs slow, is it really noticeable/obvious? sometimes I get that feeling off and on whenever I drive other people’s car or when I haven’t driven the teg for awhile. It’s all in my head I guess.
Patter$on
Might want to checkout the timing too. Should be at about 16.
1.7NA
my car was running like **** (0-60 in like seriously 15 seconds), when replacing all the injector seals i noticed that one of my injectors was messed. i replaced it and sure enough that was it.
