Will a 2000 gsr lsd fit up with my b16 obd0 cable tranny?
anyone?
your mounting together two trannies, sweet, tell me how it turns out:stare:
i believe the ribs in the casting of the b16 trans will need to be shaved in order to fit the LSD…do a search on H-T
from what i know, only the YS1 cable tranny case will accept post 93’ lsd’s
what did you hear is different between YS1 cases than others? Isn’t it just splines on the input shaft the only difference between the 2?
I do know for sure that ring gear bolt pattern between 1.6trans and 1.8 are different…Both 10 bolts though
you guys realize gsr’s never had lsd right? difference in bolt pattern seperates 92-up b-series trannies into two groups. ls/b16 and gsr/itr.
buddy, the questrion is will an 00’ lsd fit in a cable tranny case. not…“gsr cable trannies have lsd’s”
listen u little fuck. i didn’t mention cable trannies once, i said NO GSR TRANNY EVER HAD AN LSD! don’t tell me what to post, im not a fuckin n00b.
