whats up guys i’ve been thinking alot lately about swapping a H22 in my da, cause i can get one real cheap. but then i also still would like to do a b-series give me some of your opinions. It might help me make up my mind
k20
k20 Is way to much money for what its worth …in other words its a super xpensive project…h22 is gunna cost u as well…stick with tha b-series bro…b series is a blast to work with and to own…if anything upgrade to a vtec and go all motor!
i can only speak for the H22 in a EG hatch, but the one i had was fun as hell and very quick, all i had modded on the motor was a lightweight flywheel and a 6puck clutch, traded it for a turbo Z6 swapped EF hatch runnin 10psi and the EG was faster
i think it would be an ok swap if you plan to keep it mildly stock or go N/A, otherwise it will get expensive real fast
i plan on going na with it, if i do decide to do it i getting the motor so cheap and thats the reason why im thinking so much less then $1000 cheap but thank you for your feedback though
If you could get the h22 cheap then use the extra money for the h2b swap.
