The driver side half shaft (I think that is what it is called) and the three bolts were stripped going to the block. Does anybody know the size of these bolts?
BOLT, HEX. (10X1.25)
That’s the thread pitch. Not sure on length of the bolt.
Part# 23 on the illustration.
Only use oem bolts for your intermediate shaft, don’t try to use something from the hardware store.
Also, if the bolt is damaged then it’s nearly certain the block threads are also damaged. The block is aluminum, so technically the block threads should damage before the bolt threads. Pick up a tap to try and clean up the threads, but you may need to helicoil or some such thing.
