half shaft for auto and manual
Ok so I searched and no luck.
Need to know of I can use a half shaft from a automatic 91 DA to a 91manual.
I’m rebuilding my car from a stolen recovery and the engine I bought was mated to a automatic transmission. The half shaft came with it so I need to know of I can use is with a spare ls tranny I have?
The mounting bracket for the auto is different from the manual’s bracket.
No.
what mounting bracket? I’m not talking about the tranny bracket.
I just need to know of I can use a half shaft from a auto Trans for a manual tranny.
the half shafts are different
really because I took off the auto shaft from back of the motor and slipped in the ys1 tranny. it fot in just fine.
the bolt pattern for on the half shaft to the block is the same. whats different the splines in the female end of the half shaft?
The offset on the bracket is no the same. It look’s like it will work but it will not. The shaft distance to motor is not the same.
i’ve got a half shaft from a manual da. I can ship it to you for $50 + shipping.
i looked online at oreillys auto parts and there isnt even an option auto or manual and i got some axles from a friend that he said were from an auto and the fit just fine
