Just wondering how many people have done this, and if any1 has some pics of the install. I just ordered one and kinda nervous about how much custom bracket stuff i gotta do. ANY input/pics would be great, thx.
Dallas
Dallas
I have one on my DA. I had to cut the lip on the cross member so it would fit. I used two angle brackets from a hardware store and welded them on for the bottom brackets. For the upper I used one of the stock radiator hold down flipped upside down move over to another hole already there! It is not hard. If you don’t have a welder, you can bolt the brackets to the frame! I don’t have any pics to post right now, but I will get them when I can!
thanks for the input. when it comes time to do it, ill post pics as i go and see if u guys can help at all
No Prob! I look forward to see what you do!
i posted this to my build thread but what the hell… took the day off work to put the radiator in… it was too nice of a day to pass up. wasnt nearly as hard as i thought it would be, got it done in a couple of hours… test drove it for about a half and it got hot, so i got home and realized it had an air pocket at the top of the lower radiator hose. Bled the system and shes perfect. Havin all this roome in the engine bay REALLY makes me want to get this thing boosted already. anyway, on to the pics:
The crack that started to grow!
Before:
Pulled the fans… notice the discolored radiator neck, lol
the fans have seen better days, the bearings in the smaller one were gone
Radiator was missing some fins
i “tried” to fix it with JB weld… a few times hehe
radiator and a/c condensor pulled, this makes me want some traction bars
a/c compressor pulled, its dirrty but looks a lot more open
saved: condensor, bracket and compressor
had to flip the blades and wire it up backwards to be a pusher fan
modified one of the upper mounts to work with the new radiator
fan was a tight fit!
almost done
mounted up pretty flush with the upper support, i loved it
upper mount bolted down
Looks good.
