Okay so when getting hasport mounts do I get the cable mounts or hydrolalic mounts if im going to be going from cable to hydro? I would assume cable because the cable to hydro kit might mount to something itself?
If you’re putting a hydraulic transmission, you use a kit made for your car, with a hydraulic transmission,.
http://hasport.com/store/index.php/dahy.html
And you need a kit to set up for using the hydrolic set up called an actuator kit streetlightz on eBay has these items look him up tell him g2ic sent ya
Im gonna look into that but just to be clear. If I get the innovative cable to hydro kit ill still need the actuator kit and hydro mounta from hasport?
I’m getting ready to pull the hydro gsr tranny from my car today and won’t e using the cable to hydro conversion any longer. I can also check and see if the tranny mounts are different. If they are I won’t be using the mount either and I don’t mind selling them to you. If you are interested, give me a call or text. (757 412 9951).
- Rob
