HardLuck™ 93' RS build: UTAH
Hey, what brand of rotors are those?
They are made by Kinetic. These are now the 3rd set I’ve had, I had them on both my Civic’s as well and they have worked well for me with no issues…
Got the tires mounted today :slight_smile: I went with 195/50/15’s
Let’s trade wheels Bobbo!
They look great man, I really like them.
We should see what they would look like on yours, I think the colors would fit really well…
Dont know what brand it is but found this filter and intake for sale on a local classified for $40 Filter says K&N on the end of it but the pipe has no markings, so I bought it… Still need to get some new oem plug wires and maybe a new oem battery… Well here’s a pic of the engine bay as of today (Sorry for the Cellphone pic)
So I bought a newer style LS valve cover the other day… Will it bolt right up using my existing hardware or will I need new hardware for that style LS cover? Also what have some of you used to plug this hole?
edit
I lied.
http://honda-tech.com/showthread.php?t=2860200
[QUOTE=HardLuck™;2268956]So I bought a newer style LS valve cover the other day… Will it bolt right up using my existing hardware or will I need new hardware for that style LS cover? Also what have some of you used to plug this hole?
Why would you plug PCV? Should be a hole directly across on your intake manifold to run a line to. Yours looks different from mine tho.
If you look my intake is different then that photo you posted… The hose coming of my intake does not go into the valve cover it goes down to the lower part of my intake you can see where I highlighted it…
I know some people will not like my new color choice for my wheels but they are done at the powder coaters… I went with Tiffany Blue )
Last color change before you put them on? Lol
This is the first color change… They came Mag Blue from the factory but the tire shop that mounted my tires F***ed up the lips and chipped the powdercoat off… So I had the wheels Powdercoated this week the color I originally wanted them to be…
Some updates… Well photos anyways :stuck_out_tongue: should finally be lowering it Tuesday :slight_smile:
Lca’s came the other day…
Got my wheels back from powder coating…
Skunk2 FIFTY lower tie bar…
That color will contrast nicely with the white body… Good stuff!
Like I said, get at me if you need anything.
As it sits right now… Need to adjust the rear up just a little… Yes I know you a lot of you like MOAR LOW… But I like having a good riding daily driver haha
Looking good!
Thanks Buddy! You should start up a build thread for your new Score!
I’ve been thinking about it. And I think I I just might. Lol
love the wheels! once you adjust that rear ride height it’ll be perfect!
