okay so today i took my car in to get it smogged and it failed horribly.
whats done,
jdm b18b,
stock catalyst,
stock intake
stock headers
auto trans ECU(manual car)
no muffler.
2 years ago i took my car in to get it smogged and it passed with flying colors
had the stock b18a1 and catalyst with an aftermarket muffler.
if anyone knows how to read this, this is the numbers from 2 years ago.
test at 15mph(1836rpms):
%CO2 measured at 14.6, %02 measured at .05
HC(PPM) max 121, measured at 45.
CO(%) max 0.76 measured at .18
NO(PPM) max 807 measured at 255
all numbers above passed.
test at 25mph(2044rpms):
%CO2 measured at 14.5, %02 measured at 0.4
HC(PPM) max 96 measured at 42
CO(%) max 0.65 measured at 0.20
NO(PPM) max 746 measured at 314
Todays smog test results with the jdm b18b and a cat. that has been off since '08 and put back on friday.
test at 15mph(1909rpms):
%CO2 measured at 13.3, %02 measured at 2.1
HC(PPM) max 93 measured at 29
CO(%) max 0.54 measured at 0.04
NO(PPM) max 807 measured at 2395
all numbers pass except NO(PPM) which is nox i believe.
test at 25mph(2128rpms):
%CO2 measured at 13.7, %02 measured at 1.5
HC(PPM) max 67 measured at 21
CO(%) max 0.45 measured at 0.03
NO(PPM) max 522 measured at 1828
all numbers pass except NO(PPM).
my question, would the slight increase in compression from the jdm b18b make that big of a jump on the NO(PPM)?
255 to 2395 at 15mph
or
314 to 1828 at 25mph.
or are these numbers showing up because of a bad catalyst?
the smog guy told me it can either be my cat. or a change in the compression within the motor causing those numbers.
im wondering how my cat can have gone bad if it was sitting in the garage for 2 years.
im also hoping that the engine isnt the problem for not passing smog.
if anyone has any insight on this please speak. I need to get this figured out asap.
if i dont get this fixed by dec. 1st my car will be non op. until i fix it. lol
thanks ahead of time.
-karlo
