My hatch on my 90 Teg won’t open!
When I pull the lever it just goes up… does anybody know how much this will cost to fix? and is it easy to fix by urself?
Are you able to open it by the exterior key?
The cable must be broken or simply ‘disconnected’. Try to take a look under the level to see if you can grab the cable, or remove the plastic panel in your trunk and I think you should be able to see the cable…
HTH!
Had to move the thread to the Exterior forums.
Regards,
Oz
it doesn’t open when I use the key either
Oh, I see…
Time to crawl in your trunk from the front and reach under the plastic panel!
Sorry, I don’t have much more infos…
